RandMJacobs's avatar
RandMJacobs
Newbie questions
First off, I am a long time camper, but this is our first truck camper. If not for the owner raising this issue, I wouldn't be asking. Well, this is the son of the very elderly owner. He said not to fully extend the slide without a brace on the 2000 Lance 1161 he sold us...when it is on it jacks and off the truck. He also said to put some type of brace both under the slide and under the front cap when off the truck. Both sound overkill and unnecessary. I mean, I guess if we each weighed in the 400 lb range...then maybe. But my way of looking at it...if this camper is pushing 4000 lbs, I can't imagine a 225 lb and 130 lb couple risking tipping the trailer if both sitting in the dinette or both in the bed at the same time.
Am I wrong to feel any type of brace is unneeded?
Also, when camping and if we remove the camper, can I assume it doesn't hurt the camper to sit with all the weight on the jack's leg...I will lower to within about a foot off the ground. But what about when in longer term storage? I wouldn't think it would be good for the jacks to have all the weight on the jacks...what is the preferred way to leave the camper for longer storage? Could it sit on maybe 9 concete blocks spaced 3 across the front, 3 across the middle and 3 across the rear? (we just finished a construction project so have around 30 blocks we don't have plans for. Or is there a better way than the block.
I know I have a lot to learn and look forward to that, but these couple of questions are those that have cropped up in just the few hours we have owned this rig.
  • I think the previous owner was a bit of an extremely cautious type person. We have an aluminum framed Chalet camper with a slide and never has it crossed our mind to brace the slide when it is out, or the cab over when the camper is off the truck. We sleep in the overhead with the camper off the truck and have the slide out as well. As far as using blocks under the camper to store it, we let the weight of the camper rest on the jacks. With that said there is nothing wrong with using concrete blocks and resting the camper on the blocks with just a little pressure on the jacks.
