Be looking at the cargo capacity of your 1500 truck. 640 pound hitch weight on your camper, empty. Add water, fuel, gear, etc, plus whatever you have in your truck bed, and you'll have some weight on your truck. A properly-set weight-distribution hitch is necessary, as well as anti-sway bars. 32' trailer is a lot for a half-ton truck. You can pull it, but make sure trailer brakes are setup properly, or you won't be stopping it. Also, a good crosswind could get that 32' parachute swaying and throw your truck off the road. Not likely, but its possible with any trailer, and getting above 30' with a half-ton truck (in my opinion) increases the chance of something happening.
