OP Quote:
I'm still trying to understand the weight guidelines. The dry weight of the tt is 6400 lbs and the towing capacity of the TV is 8300. What else should I be looking at?
Look at it this way. If you load 1000# of stuff into the TT, which is very common, your tongue weight @ 10% will be 740 lbs. Tongue weight should be between 10-15%. Subtract the 740 lbs + the weight of the hitch itself from the "payload" capacity indicated on the drivers door jamb sticker & what you have left-over will be the allowed remaining weight of passengers, fuel, & all other stuff to include the dog & not exceed the GVWR TV rating.
What figure do you come up with ????
