BURevisfan's avatar
BURevisfan
Newbie Tow Capacity Question
Hello All,
Looking into getting a travel trailer but not completely understanding the weight ratings and how they compare to the tow vehicle's capacity.
I've got a 2015 Silverado 1500 double cab 4x4 with the V6... everything I read seems to point to 7200 lbs tow capacity.
So where I get confused is when it comes to looking at the travel trailer ratings. I'm trying to find the balance between looking at the UVW and the GVWR of the trailer.
I've had dealerships say that for the type of camping we plan on doing (established sites/resorts with water/sewer available) that by the time I take cargo weight off I should be looking around 6000 - 6200 lbs.
Where the variances come in is when I look at one trailer that has (for example only) a UVW are around 6000 lbs and a GVWR around 7100 lbs. But then another trailer will have a UVW around 5500 lbs and a GVWR at 7500.
I'm just not sure if I should be strictly going by the GVWR of the trailer, or if it's feasible to use the UVW even if the GVWR is over 7200 with the knowledge that I would still be limited in cargo to the difference between the UVW and 7200 lbs.
thanks in advance
  • With a half ton truck, your going to want to pay close attention to that GVWR. Big Truck Big RV on youtube says best to stay under 6000 lbs. Payload is going to be a big issue to watch out for.
    https://www.youtube.com/watch?v=fQZfw6wy7Yk
  • Pull ratings are only one of the at least two tow vehicle capacities with which you should become familiar. Payload is the other biggie.
    IMO your tow vehicle should be able to "pull" the trailer's maximum allowed weight. No pointing needed. Look at the sticker on the driver's door jam for maximum trailer weight and maximum payload for your specific truck.
