RetroAirBnB's avatar
RetroAirBnB
Newbie trailer owner, quite confused
I just bought my first travel trailer. A 2017 Riverside Retro 195. Mint condition with the all the manuals.
I thought: "this will be great, I'm sure I can learn everything i need to by reading the manual."
No schematics. Anywhere. And even the narrative is confusing.
It's hooked up to the battery, no "shore power" yet. And only certain electronics seem to work. Ceiling fan, outside light, radio, pump.
I ASSUME I have to have it plugged into power to get the other stuff to work, but nowhere can I find a description of what might be wired to battery and what might not be.
I'm wondering, if there are other owners out here, if I post a link to a 5 minute youtube video walking through if people could help me figure things out?
  • “OK, but maybe you can tell me this: can i connect to my home power?”
    Asking random questions isn’t going to educate you. Read about RV electrical basics.
  • bukhrn's avatar
    bukhrn
    Explorer III
    On battery, your lights will work, radio, water pump, water heater on propane, fridge will work on Propane, you still need 12V for it to work, Furnace will work, perhaps not for long, propane detector, For all your 120V things, like wall outlets, TV, AC, microwave you will need shore power, or generator.
  • RetroAirBnB wrote:
    OK, but maybe you can tell me this: can i connect to my home power? Manual says I can, but have to turn off all breakers in house and trailer first, then turn on. For some reason.
    Standard CYA by the manufacturer. At home most people just plug in with no issues. If at a campground most people flip the main breaker at the post off before plugging or unplugging. But the rest of the breakers stay on.
    Just plug it in and see what works.
  • Make sure the battery is hooked up correctly. Turn on the overhead lights as a test.
    Your battery should run:
    Overhead lights
    Light over the stove top
    Any fans
    Water pump
    Refrigerator on LP
    Water heater on LP
    Electric awning
    outside lights (Except) the running and taillights
    Slide out
    Items that you need to be plugged into shore power for:
    Microwave
    Refrigerator on electric
    Water heater on electric
    Air Conditioning
    All the 120v household style plugs
    Battery charger
    All the other items from the battery list above also
  • OK, but maybe you can tell me this: can i connect to my home power? Manual says I can, but have to turn off all breakers in house and trailer first, then turn on. For some reason.
  • find a trailer in your neighbor hood and go ask that person to do a walk threw with you, take notes. and bring a six pack.
  • If the “stuff” is the AC, microwave, 110 plugs and most TVs, yes you need to plugin or use a generator. However, most of us use an inverter for the TV...turns 12 volt battery electricity into 110.
