Terryallan wrote:
so. 65 to 70. That is the top, and over the top speed your tires are rated for. Slow it down.
As mentioned. Air your tires, Trailer, and TV to their max PSI. The TT will follow anywhere you want to go.
Air in my truck tires are Max at 80psi. I made the mistake and air it to 65psi prior to picking ups the truck. BAD move as i was going around a turn, hit a few bumps and went sideways a tad. But I also feel that air the tires up to their max would be to much if I don't have the appropriate load...right? Trailer tires definitely looks tad soft, so I agree maybe airing it to the max-5psi..?
