Bigfoot affair wrote:
jfritz_drfritz wrote:
You really need to ask this question on a gm dedicated website like dieselplace, I don't follow the duramax too much since I am a ford guy, but I am aware that there are certain years of the duramax (?LB7 model) that had a lot of trouble with overheating. If your truck is one of these years (I thought they were fixed by 2008) , it is unlikely that anything you do to the radiator or fan clutch will remedy the problem. The cause may be more complicated. Ask someone who supposedly knows!
Once again... LLY (2004-05) where the ones that MAY have the issues of running hot... 2008 would have an LMM.. Same engine as the sought after LBZ, only difference is that the LMM has a DPF.
LOL
Yeah the DPF is no big deal in 2008 MY's :W A LBZ is a LBZ, the rest are not the same, check tail pipe.
