LosAngeles
Oct 22, 2020Explorer
ticki2 wrote:
Check your door sticker . It may be that your truck is only at its rated GVWR . If so you shouldn't even need the stableloads . Also check the tire pressure for the load they are carrying . Over inflated tires can do that . That being said there are roads that are miserable no matter what you do . The old concrete paved roads come to mind .
Tires are at the pressure Ford recommended.
Truck is well loaded, level, even.
thanks
