Vinsil wrote:
I have too much sag. Once I hook up my trailer.
My truck sits about 2-3" too low. Now I have not loaded up since the tires, sway was ok but it did still sway a bit. I think the new tires will take care of most of that problem so I'm trying to accomplish keeping my truck level and springs from going negative on me. I carry a lot of weight.
no more than me, with my dually I scale at 13,500 with just the truck and TC I was close to 13 with my srw and 19.5s and I pull a three horse slant load
On the 2003 F350 SRW with 245/70R19.5s I had upper stable loads, Airbags, front and rear Roadmaster Anti Sway bars
2011 F350 Dually Upper and lower Stable loads factory antisway bars 265/75R17s
I do like airbags because I vary how many horses I carry (1000-1200 pounds per horse) and the bags can quickly adjust for the weight difference. The Dually works well as it is with one horse on board but needs more than the 3 wedges of the lower stable loads when I carry two big horses two sets of tack and 3-4 bales of hay so its going to get the addition of aribags for use when I neeed it.
