eluwak
Jan 26, 2016Explorer
Nascar24 wrote:
After a little more research I found on the Edmunds site the pay load specs for my 08 V8 Pathfinder is 1480 lbs, lot more than I would have thought, some 1/2 ton pick-ups don't have pay loads this high
No.
Look at the sticker inside the driver door. My 2012 V6 S (zero options base model) was around 1100 lbs, and verified by CAT scale. All Pathfinders in that generation had the same GVWR, and the suspension is terrible for towing heavy. You're hitch rating is 700 lbs, which you'll blow by too.
edit:
The trailer was ~4500 lbs. unloaded, and I had airbags preventing the truck from dragging on the ground. The experience was white knuckle for the 400 mile round trip.
