Fixed_Sight_Tra
Jan 26, 2016Explorer
I use a Z71 Tahoe to pull a 23' Toyhauler. About 7K#. I does it okay but I'd rather have something bigger.
How much are you planning on towing? If its just a few hundred miles per year then you will be fine. If you want to go cross country you will probably end up destroying your pathfinder.
If not installed you will probably want to get a transmission oil cooler. And make sure you change the fluids often. And make sure your tires are rated at least as high as the vehicle and are properly inflated. You said you have experience towing but all these become more important when you are towing at the limit of the vehicle.
But as I said, for short trips you will be fine.
