shum02 wrote:
ShinerBock wrote:
shum02 wrote:
ShinerBock wrote:
Technically, the Titan XD is in the same 2B trucks class as all the other current 3/4 ton (HD) trucks and SRW 1 ton trucks from a decade ago. Regardless of anyone's opinion on the matter, it is and 3/4 ton based on its ratings. Just a smaller version with similar ratings of a 5.7L Ram 2500.
A properly equipped EB F150 can do it's specs or more.
What does that have to do with what I stated? Not getting defensive, I am just asking because I don't see how they relate.
Also, I had a custom tuned F150 HD with a 3.5L EB so I know what they can do.
It's not a "3/4 ton" truck. The insistantance that this and other half tons by their rated or perceived capabilities make them anything more than they are has worn thin. This truck is pointed right at an EB F150.
Let's not put it on a pedestal.
But it is a class 2B truck based on its specs which is the class all other trucks people call 3/4 ton are in. That is a fact that cannot be changed by opinion no matter how adamant that opinion is.
The 2B class trucks that most consider to be a "3/4 ton" has a GVWR between 8,501 GVWR and 10,000 GVWR. This truck has a GVWR between 8,600 and 8,990 lbs so it is a class 2B truck. If what you deem as a "3/4 ton" is based on payload ratings like it was back in the day when the term had real validity, then it still fits the bill since even a decked out XD has a payload greater than 1,500 lbs (3/4 of a ton).
I am not putting it on a pedestal and would probably never buy one of these trucks. I am just stating facts regardless of my biased opinion.
