- dave54Nomad
jfkmk wrote:
TucsonJim wrote:
2oldman wrote:
A nitrogen post, and a Walmart post in the same day. Wow.
Hey, if we get a "winterizing" question, we win the trifecta!
Would a wheel bearing or a ST v LT thread suffice?
Depends... Is the propane on or off? jfkmk wrote:
Last I read Nitrogen is just for ST. LT can handle the polluted air of any big city.
Would a wheel bearing or a ST v LT thread suffice?- darsbenExplorer II
ORbiker wrote:
I have my own nitrogen tank I got when my brother's motorcycle shop went out of business.
Temperature has a lot to due with RV tires having issues. Nitrogen helps with that.
In a pinch, use air.
I find it hard to believe the small difference in nitrogen levels would make a difference in tire temp.
After all you are talking raising nitrogen from 78% to 95% which still is not pure nitrogen.
Dump the nitrogen. - jfkmkExplorer II
Would a wheel bearing or a ST v LT thread suffice? - ORbikerExplorerI have my own nitrogen tank I got when my brother's motorcycle shop went out of business.
In a pinch, use air. - TerryallanExplorer II
dave54 wrote:
downtheroad wrote:
Nitrogen is so yesterday...
I put testosterone in our tires...
I use helium. My rig just seems to float down the road...
AND you can leak some out , and talk like Chip, and Dale
Where do you get it? Can you use the balloon filler bottle? - dave54Nomad
brackleybeach wrote:
It's Ok to mix summer air with nitrogen but if you have winter air in the tires then you have to make sure it is all removed before adding nitrogen.
Or buy that Australian air. Their seasons are reversed. Of course, if you use Australian air you have to put the left tires on the right side and vice versa. Else the air will rotate in the wrong direction and damage the muffler bearings. - dave54Nomad
I use helium. My rig just seems to float down the road... - _1nobbyExplorerThe rule of thumb is:
ONLY add nitrogen to your tires when you service your blinker fluid. - gboppExplorer
loryray wrote:
Can air be mixed w/nitrogen in tires. Dealer said NO. does anyone Know for sure?
You need to find a new dealer, real soon. You are being scammed.
44,068 PostsLatest Activity: Jun 10, 2026
