maxwell11's avatar
maxwell11
nitrogen in tires
we bought a used 2013 Toyota Sienna van, 39K miles, a few months ago and it has the green valve stem caps, so I assume it has nitrogen in the tires. Still has the original equipment Michelin tires on the vehicle.
do any of you guys run nitrogen in your truck tires, if so where do you get the tires filled, if you need to top off a few #'s from time to time?
what happens if I place a few #'s of air from my home air compressor,
say from 30 to 32 #'s in these tires?
Thanks for any input.
Have not checked tire pressure in the tires, but need too.
tires do not appear to have lost any air since we have owned the vehicle, but who knows as I had no way to add more nitrogen, if needed.
  • RAS43's avatar
    RAS43
    Explorer III
    campgrammie wrote:
    I am getting that you can just add air to tires that have nitrogen in them correct? My son just bought a trailer and his tires have nitrogen in them. Its only a 2 year old camper and this was his second time using it and he got a blown tire on the pike.Luckily he kept it under control and not much happened only a crack in the bumper and the need for a new tire. We have been camping for years and never had a problem like this. And we never heard of tires with nitrogen so its all new to us. Any imput on what could have happened? Could it been because they had nitrogen in them?
    Yes, you can just add air to the tires as air is 77% nitrogen. As mentioned by others, filling with nitrogen is a marketing thing by some tire dealers.
    And no, the nitrogen did not cause the blowout. It was probably low on air, damaged, overloaded, or a cheap tire- search "China tires" and be ready for a lot of reading.
  • I tell folks that if they feel better paying to have nitrogen put in their tires, by all means pay for the nitrogen. Personally, I'll use good old plain air.
    No way using nitrogen in a tire would cause a blow out unless it was under or over inflated of the tire hit something.
    Ken
  • In all the years never heard of nitrogen in tires. Must have been under a rock. He did say the pike was under construction and was tore up. He probable hit something. But I will also pass on the china tires for him to have some interesting reading. No matter how old they get we still look out for them. thanks
