maxwell11's avatar
maxwell11
nitrogen in tires
we bought a used 2013 Toyota Sienna van, 39K miles, a few months ago and it has the green valve stem caps, so I assume it has nitrogen in the tires. Still has the original equipment Michelin tires on the vehicle.
do any of you guys run nitrogen in your truck tires, if so where do you get the tires filled, if you need to top off a few #'s from time to time?
what happens if I place a few #'s of air from my home air compressor,
say from 30 to 32 #'s in these tires?
Thanks for any input.
Have not checked tire pressure in the tires, but need too.
tires do not appear to have lost any air since we have owned the vehicle, but who knows as I had no way to add more nitrogen, if needed.
  • RAS43's avatar
    RAS43
    Explorer III
    If I can get nitrogen for free and don't have to go out of my way then I'd get it. Costco fills all tires with nitrogen when they mount them so my new tires on the truck and 5'er have nitrogen in them. If I need to adjust the pressures I use my home compressor. I really haven't seen any difference in pressures in the two years the tires have had nitrogen in them. Maybe for race cars and airplanes it is worth it!
  • The nitrogen fad has been debunked so far as I know. As Mitch above points out air has 78% Nitrogen in it already.
    BK
  • My wifes Rav4 had the green caps on it when we bought it used in 2006 (it's a 2003) and I had to top it off with 78% nitrogen from then on... After a few times of topping off and then getting new tires not too long ago, I found I didn't have to "top off" as often..
    To me, it seemed the "nitrogen" filled tires lost PSI faster than it does with just "air" in it...
    Dunno what the deal is with paying extra for the green caps when regular compressed air works just as well and I don't seem to lose as much PSI a month either....
    If it was me, I'd just use my compressor... ;)
    Good luck!
    Mitch
