mike-s wrote:
time2roll wrote:
The compression process provides a very dry product so there is never a moisture issue to affect the tire, wheel or TPMS.
You obviously don't have a compressor. The air inside the tank is at close to 100 percent humidity (you need to drain water from the tank on a regular basis). When it comes out, the temperature drops and that moist air turns into moist air and water. Their's a good reason they sell water separators, dehydrators, dryers to put on compressors.
Yes, there's less water coming out than going in (which is why the tank needs regular draining), but what comes out is by no means "very dry."
We had several air compressor units at the power plants
400# Soot blowing air systems'
100# general service air systems
100# Instrument air systems
Both soot and general service air was 'dirty/moisture laden' because they were just fed from an air compressor...just like the air from any air compressor
Instrument Air had to be CLEAN & DRY
Same old air compressor...air went to same type of storage tanks which had to be blown down occasionally due to water build up in bottom of tank BUT the key was air then went thru set of filters and a chiller unit to clean & dry it PRIOR to use.
Air compressor alone will NOT make air clean/dry.
Nitrogen...is drier gas
RV Tires are filled at factory by RV MFG.
IF RV Dealership is providing FREE N2 ---great
IF Charging for N2 -------PASS
Either way....sooner or later you will need to adjust RV tire air pressures. AND good changes are that will be done the old fashion way........with an AIR Compressor.
Never PAY for N2. Benefit/cost does NOT make it worthwhile
