kohldad
Nov 15, 2017Explorer III
I believe so as the DRW bed didn't change until 2013. That change only re-enforced the rear of the bed rail by angling it slightly, about 1" in on each side. This can would be the only dimension that you need to double check. My father's 1999 Bigfoot still cleared though even with it's wider area behind the wheel wells. The only other possible issue could be the bed rail height if yours is new enough to have the plastic cap, but again, something I don't think they did until 2013. This one is easy to fix with a 3/4" platform under the camper.
