AH64ID
May 09, 2014Explorer
fla-gypsy wrote:
The OP said it "seems" the compressor is running indicating he really didn't know and since he was attempting this on a 15A circuit it is reasonable to assume he doesn't have enough power to start the compressor. The fan will run but he obviously doesn't know if the compressor is running and most likely it is not with 15A service as pointed out by many of us.
If a 15A circuit won't run it then it's because the breaker tripped and the fan wont work. It's that simple. Breakers do not limit current flow, the open if too much heat is created in them. The heat is a byproduct of too much flow. They will flow everything they can, often a little more than 15A on a 15A circuit, until they overheat.
