MartyG2
May 11, 2014Explorer
Don't think of an AC circuit as how much it will supply, think how much can be pulled before the breaker trips. Your AC is not drawing enough to trip a 15 amp breaker. It won't draw any more current even if it were on a 30 amp circuit. I believe, like the others, that since you obviously have voltage to the Air Conditioner, and the fan works, then the only reason you're not getting cold is a fault of the unit itself. Most probably a Freon like, as others have said.
