So i will pick new pig tails up this morning,and report. Hope it fixes things or may postpone tomorrows departure.
I switched tank sides/pig tails bad tank ran now the stove,but will not run the heat.Or will run heat but not stove. There are still times when the stove 2/3 burners will run and the new regulator indicator will be red. Seems gas volume is just not enough to support more than 2 burners and the heat on the good side. Bad side lucky if it can support one burner.
Filled canisters at Costco, anyone with issues ?
