Sir_Buffalo's avatar
Sir_Buffalo
No heat
Need assistance furnace is in the on position I have full propane tanks and they are turned on
Thoughts
  • The fuse would be a symptom of either an overloaded circuit or a short.
    So it may not stay fixed very long.
  • Hi Sir Buffalo, Are you saying a fuse fixed the issue? Or were you saying thanks for the suggestion and you'll investigate the fuse? If it's not fixed can you give us more symptoms? Are you turning the switch or? Is the fan coming on but no heat? Does the fan run for a minute or so then turn off? Do you hear any noise at all?
    Hopefully you already have it fixed.
  • Does your thermostat have both an on/off switch and a temperature selector? Most of them do. The switch needs to be on.
  • Furnace operates on 12V. Check your fuses. Do other 12V items work? Lights, etc?
    When you turn the thermostat on does the fan come on?
