Rickbier
Dec 26, 2014Explorer
No hot water
I recently changed my drain plug on hot water tank now there is only about 2-3 cups of hot water then it cold thinking tank my have air it it I open all valves ran water even drain fresh water tank st...
'tiredTeacher wrote:
Do you have a bypass kit installed for winterizing?
If yes, check the position of the bypass valves.
Then open the relief valve on the tank and make sure the tank is filled.
Teach
