Dick_B
Nov 05, 2016Explorer
Check the power to the fuses. If no fuse power trace the wiring from the battery to the fuse box. Our rig had a manual reset circuit breaker located under the rig at the left front corner. Our dealer replaced it with an automatic reset breaker. As I remember it is a small metal box with wires running to and from it. Never knew it existed until it want bad in the dealers driveway.
P.S. the lights work off the battery. The outlets work off the shore power.
44,029 PostsLatest Activity: Jan 13, 2025
