Shchcuck's avatar
Shchcuck
No More Dead Batteries
I just got a volt-minder and tested it in the shop to night and it works very well.
You set the voltage you want for a low setting then if the voltage drops to that set point and stays there for 25 sec. or more it will sound an alarm and flash the display you then have time to start your gen. set or your TV once you get the voltage up again it will shut off.
You can use it in your TV TC or TT it just plugs into the power port ( Cig. lighter) move it when you want
The best part $45.00 to your door
Web link http://www.voltminder.com/
If you order one please tell him that Chuck saiid it works and to call
Have fun
Shchuck
