KKELLER14K wrote:
Replace the 7 pin....and work your way back to the front..It could be something so simple like a ground wire.....keep at it. You will find the fail. 7 pin plugs go bad all the time..when did you use it last? How did you know you were not getting power to the RV?...I'm stummped here...External charging wire? WHY? SO...you have 2x 7 pin connectors? My truck does....but you say your using the rear plug on the rear bumber? This is confusing...if I try to help we all need more detailed info. The TC power is hooked up where? Do you have a battery switch? Connected to the fire wall? For a second plug?
When you have two seperate systems that supply power to an RV it is common that the rear bummper plug will be hot while the rig is running but like mine it is split... When you turn off the rig, the bateries are seperated from the RV. I have a 7 pin on the front interior of my truck bed. I have a 7 pin at the hitch. The wiring at the bed connection is beefed up from the factory because I made that tweek to help make the batteries get more power when we travel.. I hope this makes sence..I was running dual 36 Interstates with a 100 watt sollar. All I needed. I am not going to rule this out...but have your alt checked..It is the prosses of elimitation...keep working you will find it!!!
Really appreciate you taking the time to make a detailed reply!
Should I replace the 7 pin on the truck-side or the camper-side?I bought the camper used, so I haven’t gotten the alternator to power the 7-way at all, but I used the running lights today.
I know I’m not getting alternator power to the RV because when I check across the battery terminals with a multimeter, the voltage doesn’t change after turning the truck on.
The external wire was something that had me really confused too, but after asking on here it’s apparently a small wire that allows power to run from the truck to the 7-way, but for some reason it’s not connected or fused by Chevy out of the factory, so you have to do it yourself.
There sort of is two 7-way connectors, the truck has one in the rear bumper (which I’m using) fully wired up that came with trailer package, but there’s also a bundle of wires under the middle of the truck that you can connect another 7-way to. I had no idea about that one, but I was following the rear bumper connector wires to look if it was broken anywhere and happened to see a wire bundle.
By battery switch do you mean the disconnect switch for the camper? I have one of those, but I think there’s also some kind of switch that disconnects the camper from the truck batteries.
What is a fire wall? Sorry, I’m still learning all the terminology.
It sounds like with two connectors, one is only hot when the truck is on, but the beefed up one is always on? Funny you mention solar because I was just thinking I should just get solar and forget troubleshooting the 7-way! It’s been three weeks of repairs and maintenance with the camper and morale was getting low, so thanks a lot for the encouragement, I really need it!!
