stupendous_man's avatar
Mar 03, 2022
No Power to 7-Way Plug?
Hi all, electrical problem’s got me stumped. I’m no expert so I figured I’d ask some.
I have a 2000 Lance truck camper not receiving alternator power from my 2009 Silverado 3500. The truck has the heavy duty trailering package, so the plug is attached to the rear bumper. I went into the fuse box under the hood and attached the external power wire, adding a fuse.
As I understand, the truck-side 7-way plug has ground on the bottom left and 12V power on the top right. When I check these with a multimeter, I get 0V. I also have a bundle of wires in the middle of the truck for an additional 7-way.
The running lights, turn signals, and brakes all work with the rear 7-way plug. It appears the previous owner replaced and rewired the camper-side plug.
I don’t have a lot of experience with RV’s, so let me know if any of this needs clarification. What could be going wrong here?
Thanks!
  • Now you are learning RV stuff. congrats.
    If you really need to charge the camper battery from the truck, then you can use bigger wire, and not go through the thin wires around the fuse box. Make sure that stud #1, that some say is on all the time, is NOT on all the time or if you forget to unplug the trailer from the truck you could run down your truck starting battery. You need the trailer 12 volt power to be connected to the ignition somehow, and not straight to the on-all-the-time battery. Sounds like previous owner did some home-brew electrical kanosh work...
    but you got it working, so good nuff for now...
    Other option is a DC to DC charger.
  • I may have been a bit misleading. So It is an isolation switch that you install usually on you firewall and beef it up with a bigger charge wire than stock. It is powered directly from the truck batteries. When you turn on the truck, the isolator opens the flow of power. When you turn it off, obviously it closes the flow of power beteen the truck and RV. The reason I set up my 2 sytems was first, I could deliver more power to the TC. Again running dual batteries in the truck and the TC. So I used the stock bummper 7 pin to plug in my boat so I could keep some power going to the boat batteries...just redundicy and peace of mind. That bumper connection is also isolated but just not as powerful. ....HEY! congrats you are getting a good education.
