way2roll wrote:
It's the same transmission and you are correct there is no scheduled maintenance. That said, I've read that it's recommended you change the transmission fluid around 90k miles.
I have a 2020 F350 6.7 and the transmission is starting to concern me. Aside from shifting very hard in 2 and 3 (it's always done that), the other day it shifted out of drive. I started to pull out of my drive and it just disengaged for about 10 seconds, coasted and then only revved until it banged into gear eventually. Thank goodness I hadn't pulled out onto a busy road. I've also had issues in 4WD. I was towing in some sand a few weeks ago and I put it in 4WD. it started to work fine at first and then wouldn't take fuel at all. It just died when I hit the the throttle. Of course I've had these things investigated at the dealer and they can't ever seem to replicate the issue. We are downsizing to a smaller motorhome and frankly I'll be glad to be rid of the truck. It's nice when it's working but I cringe at potential issues on such an expensive truck. I sleep better knowing it's still covered under warranty but I really worry about long term issues with it. Been lots of reported issues with the new transmissions and in most cases Ford doesn't want to step up.
Sounds like a lemon. Ford is not using any new 4wd systems. And the trans? Idk.
Usually when I have a warranty issue like this I try to make sure I break it good so there’s no question what the dealer goobers need to replace!
