rvhippo wrote:
Is the design such that the entire wall is waterproof or is just the wallpaper waterproof?.
I had a 2010 X17 with what sounds like the same wallpaper but with no punctures other than the ones I put there when mounting my shower caddy. Those were well sealed with silicone bathroom caulk.
The wallpaper is waterproof. I do not know about the structure behind but I would assume that it is not. Staples and screws poking through sounds terrible and I guess they must have given up compeletely on QA.
I suggest taking good close up photos with a real camera of these staples and screws and then sending the photos and asking the dealer what can be done about it. You can also contact the Jayco dealer Rep and see what s/he says about that after seeing the photos.
If you can find a way to seal off these breaks in the waterproof wallpaper then you should not have problems with water incursion behind. But you also should not have this in the first place.
