dadmomh
Jan 10, 2015Explorer
I think all the things on your wish list are likely doable....except for the washer and dryer. Since we got into the RV lifestyle in '06, the only units I can recall seeing a w & d in are the larger motor homes. Certainly not to say you could not retrofit, but first you have to get the things through the door. Plumbing work. Then in the 24 - 28' size, something is going to have to go to make room for them. I would not put appliances with their weight toward the rear of the trailer. Don't know if you have thought of this, but what about a toy hauler? You wouldn't have the issue of cramming the w & d through a door, although they would be toward the rear, you could mod the area to suit your crocheting needs or whatever else you might need. Our 26' has swivel rockers rather than recliners and I'd bet they were set into the unit before the walls were up. My dear cousin and hubby checked into removing their sofa and putting in recliners and the only ones they found that could have the back removed from the seat and were small enough to get through the door were LazyBoys and were very, very $$$$. Something else to check into. Still think most of this is possible, but you're going to have to be very creative. Best of luck
