pianotuna
Jan 13, 2015Nomad III
Hi Sara,
There are some guidelines. The absolute minimum for battery charging is 60 watts per 100 amp-hours of storage. The "reasonable maximum" is 150 watts per 100 amp-hours of storage.
If you full time and boondock and are running a generator for 120 volt power then it is best to maximize the shade free space on the RV and populate it with panels. Costs for a DIY install are under $2 per watt.
I'd further recommend a hybrid inverter--because that will allow the battery bank to supplement shore or generator power. This means a smaller cheaper generator can be used--and that fuel costs for it are reduced.
It may be wise to consider switching to a 24 volt battery bank, and using DC to DC converters to power the 12 volt stuff in the RV.
crochetdiva wrote:
Thank you. I'll have to sit down with my husband and try and figure out how much we'll need. I wish there was an average that you could start with and you could just add to it.
