befu
May 28, 2013Explorer
My puma has a 15 amp fuse under the trailer frame at the front. If battery is dead and I hook up the 7 pin, it will blow that fuse. I would suspect that fuse or breaker as mentioned earlier.
After winter I did not have a battery in it yet and was not hooked into shore power. When the slide came all the way in and the drive started to slip, the fuse popped then also.
Good luck
Good luck
44,056 PostsLatest Activity: May 04, 2014
