Oaklevel
Jun 02, 2013Explorer
Gdetrailer wrote:
Bear25314 writes "I didn't have the batteries on the trailer. "
:E:M
Umm... You do realize that you MUST have fully charged batteries CONNECTED to your trailer ANY TIME you venture out on public roads?
The reason for this is the trailer battery(ies) are SUPPOSED TO PROVIDE POWER FOR THE BREAK AWAY SYSTEM.
By not having a charged battery attached to the trailers electrical system your break away system will FAIL to operate once the trailer to TV cable disconnects if for any reason your trailer fully breaks away from the TV.
This IS a Federal requirement and IS enforced by all states (yeah I know, TEXAS doesn't obey any Fed laws :R :h).
It is not only a safety item for your sake but also ALL of the motorists on the public roads.
Y
The break away system is required to not only STOP the trailer from rolling but alos HOLD the trailer in place for a minimum of 10 minutes.
It is there for everyones safety, USE IT.
Not only use it, CHECK IT EVERY TIME YOU HOOK UP to tow.
When hooked up, simply pull the plunger, then try pulling forward, the brakes MUST lock and you will slide all tires.
If the brakes fail to activate DO NOT TOW UNTIL YOU HAVE LOCATED AND REPAIRED THE PROBLEM.
X2 !!!!!!!!!!!!!!!!!
Also the trailer battery may need to be in the trailer for the 12v systems to work.....My slides will not work with the trailer battery out it may be the same for the jack...........
Also some tow vehicles have separate fuses for the trailer plug....
Good Luck !!!!!!
44,056 PostsLatest Activity: May 04, 2014
