kennyd63's avatar
kennyd63
No water in trailer...
After arriving at the CG, and hooking up to the city water. I found out that I had no water in the T.T. I removed the screen that is hookup to the T.T. to make sure that there was nothing blocking the screen. everything was clear. After removing the screen I notice there is a white plastic nipple and in front of it there is a metal spring I try to adjusted but I still do not get any water in the T.T. Please help!!:S
Thank you,
  • Short term, if you can't solve the problem, fill your water tank and run off the pump.
  • Jim Cindy wrote:
    Check for winterizing valve in the line, turn 90 degrees.
    Yep. Been there, done that. It will probably be near your water pump.
