AnEv942
Oct 18, 2017Nomad
Low point drain per title (plumbing waterline drains) or the drain line on tank as described?
Is it small plastic 1/2 turn ball valve? Line clear tube? if you have access pinching, or milking toward valve can sometimes start flow. Ours if hasn't been opened in a while will clog with scum (white). I wouldn't push it back into tank. Ours runs from front to back of camper though so a lot of non moving water.
With the slightest bit of flow I'll quickly tap valve outlet, stopping water flow, let it flow, tap it again, forcing just a bit of water back up or pulsing water in tube. Doing this quite a few times will generally loosen up the scum, and eventually clear.
I can only assume valve and tube, but if like ours and most Ive seen I wouldn't apply much pressure/vacuum likely just suck tube closed if blocked at tank.
If its the little ball valve though removing it to expose end of tube, ours is barbed, something like a turkey baster to pull and push water would be the most force I'd apply.
