schlep1967
Sep 14, 2020Nomad
carlos6466 wrote:
I removed and replaced the one way valves (back-flow valves) on the end of the inlets as one was defective yet water still is only a trickle.
This is probably your answer. In the line right after where this faulty check valve was replaced you will likely find a piece of the old valve at the first elbow or tee. It will be kind of "T" shaped like a valve in a gas motor.
When the spring clip comes off stem of the check valve the valve then travels down the line to the first restriction and then become a plug.
See the second picture at this link Check valve parts 5th item from the left is what you are looking for.
44,068 PostsLatest Activity: Apr 17, 2021
