OhhWell wrote:
Huntindog wrote:
What exactly am I to "get over"?
I have both generators at my disposal and can use whichever one I want..
I choose the Hondas for the fuel savings.
As far as "qualifying" my statements.... Just how far do want me to go to satisfy you? Times, dates, tempertures, altitudes, specific loads ?
There will never be enough "qualifying" to suit some that have a different OPINION...
So I won't bother trying to please those.
But I will say that it is a pretty safe bet that the vast majority of TT owners use their generators mostly to keep the batteries up, and occasional microwave use. For that the Hondas will use SUBSTANTIALLY less fuel... And yes we have done side by side comparisons on this.
My brother powering his rig with the Champion, and my rig being powered by the Honda. I even have more load as I also have a small external freezer that I bring along.
And as far as how much a Honda will use at full load compared to the Champion?
I honestly don't know as I have never run at full load for enough time to tell... But that's OK as those that are dissing me don't know either as they don't have a Honda to test..
Perhaps what we have here is a severe case of generator envy.:B
I have a 5.5k Onan that uses less fuel than your little red box watt for watt and is quieter in the campground when I hook up my Genturi. It also starts with the touch of a button and has a 50 gallon gas tank. Tell me why I am envious of your "cheap" little red generator because I also own a Champion 3500w again? :B
It's a completely safe bet that almost all of the TT owners and campers in my neck of the woods need something with actual capacity in the summer.
You admittedly have no idea what your Honda consumes under a load but we cannot either even though Honda publishes fuel consumption numbers? There is also a gentleman who gave the Honda a real world test here:
http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/24022161/gotomsg/24963199.cfm
Remember that you will need TWO Honda EU2000i's to match the capacity of the Champion. (or about 3 to match my Onan)
The inverter generators are great and I wouldn't mind having one. They are absolutely brilliant if you don't need much power capacity but they don't bend the laws of physics.
It always surprises me how little people know about efficiency. You need to design the system for the load level that is used the most.
The inverters allow a variable size source to be used. The inverter can be a small generator or a large generator and be efficient at the same time.
The large synchronous generator must run at fixed speed. The last thing I would want is an 8hp – 12hp engine running all day to provide 8 AMP VAC to power a battery charger.
Mm49
