Huntindog wrote:
OhhWell wrote:
Huntindog wrote:
Someone must need a nap.:B
Do you have both generators? I do. You may not like my opinions that were formed from real experience....
My advice to you is.... Get over it.
And don't even try to bully me, by telling me how to post.. Once again... Get over it.
By not qualifying the actual real experience (ie. amount of load on the generators), you spread miss information. A blanket statement about the traditional generator (Champion) guzzling fuel compared to the Honda is false (well, maybe true in a subjective manner) under high loads.
Maybe it is you that should "get over it"
What exactly am I to "get over"?
I have both generators at my disposal and can use whichever one I want..
I choose the Hondas for the fuel savings.
As far as "qualifying" my statements.... Just how far do want me to go to satisfy you? Times, dates, tempertures, altitudes, specific loads ?
There will never be enough "qualifying" to suit some that have a different OPINION...
So I won't bother trying to please those.
But I will say that it is a pretty safe bet that the vast majority of TT owners use their generators mostly to keep the batteries up, and occasional microwave use. For that the Hondas will use SUBSTANTIALLY less fuel... And yes we have done side by side comparisons on this.
My brother powering his rig with the Champion, and my rig being powered by the Honda. I even have more load as I also have a small external freezer that I bring along.
And as far as how much a Honda will use at full load compared to the Champion?
I honestly don't know as I have never run at full load for enough time to tell... But that's OK as those that are dissing me don't know either as they don't have a Honda to test..
Perhaps what we have here is a severe case of generator envy.:B
Huntin' First of all, IF your wattage "needs" are so small then why on earth would you intentionally buy a 4Kw gen?
A 1Kw inverter gen would be all you "need" according to what YOU have posted.. Pretty much stands to reason that if you have a small load then a smaller gen will consume LESS than a bigger gen with the same small load..
Personally, with your such small demands, you should have simply spent the money on SOLAR PANELS. For the thousands of dollars you have spend on gens and fuel you could have easily bought 500W or more in solar panels. Then you wouldn't be griping on how much fuel a 4Kw gen uses..
Besides I am getting the feeling that you never really had a Champion to start with.. I smell a
RED troll.. :S
