ADA6969 wrote:
Just talk to A/F Said to move sensor to bottom of cooling fin. Will try??
OLD-BISCUIT. Your info is great. Looked at the dirt unit is brand new.
Thank you Andy
Move the sensor to bottom of Fin??
Do you mean the Thermistor on Fin in food compartment?
Yes...moving it DOWN causes warmer temps---moving it UP can cause cooler temps
BUT only by 4*f - 6*F difference
AND that is minor adjustment for Models that have NO temp Adjustment Setting (Auto Temp Control)
Besides....fridge cools properly on AC Element
Uses the SAME thermistor/thermostat as the GAS does
Element and GAS produce/transfer roughly the SAME heat energy to coolant
Somebody was blowing smoke up your woo-hoo!
Spider Web can disrupt fuel/air mixture causes poor flame temps
Low LP System Pressure...cooler flame
You have an issue with Gas...LP pressure/flow, flame temp, heat transfer etc
