Carvhors's avatar
Carvhors
Norcold fridge not powering on
I have a 2016 Norcold N306RM8 fridge. It has been working fine. That last time out we ran the fridge on propane for 4 days. Fast forward to yesterday: Getting ready for a trip this weekend and turned on the fridge to get it cool before we leave, and there is no power. The power indicator light is not powering on on the front panel. I checked all of the breakers and fuses in the main panel - are all good. I checked the DC outlet the fridge is plugged into and that's fine. I checked the AC power coming into terminal board on the back of the fridge and I'm getting a reading of 13.5 volts. I'm connected to shore power. The battery bank is fully charged, and all other 12v items are working fine. I even unplugged the fridge overnight to see if that would reset something. No go. Any other ideas I can check? This is a low-end model and pretty basic. I really don't know what else to troubleshoot. At least I'm able to run it on propane for now. Any help would be greatly appreciated!
  • Volts are good. 13.5 is a normal battery voltage.
    Look on the main board for a fuse. There should be at least one. If fuses are good, then its a good chance the board is toast.
  • The dual 6v battery bank has been on float charge (plugged into shore power) for several weeks, so showing a 13.5 is normal. It will need to settle out with no charging or load for 6-12 hours to get a true reading.
  • Let me double-check that. I took that reading in the dark at 1:00 a.m. this morning.
