CarterKraft
Sep 11, 2013Explorer
As others have said, you are reading what is refereed to as pull up voltage. It allows the controller "or any ecm" to see a load attached.
And as others have said the test is meaningless without the load attached, the load can be the brake coils or a high wattage bulb or similar load.
I read but didn't actually see a problem you described, do the brakes just not work effectively? If not have you just tried connecting the brakes to a 12 volt power source and see if they lock?
44,056 PostsLatest Activity: Jan 12, 2020
