nomad297
Dec 06, 2014Explorer
Normal Transmission Temperature?
I own a 2004 2500HD Silverado with the 6.0 gas engine.  They must have run out of the correct instrument clusters while mine was on the line, so I was blessed with a transmission temperature dummy light instead of an analog gauge.
I recently had to replace my cluster due to lighting and gauge problems, and the new OEM cluster (not rebuilt) came with the transmission temperature gauge. Everything on the new cluster works fine, but I don't know where the needle should rest at cold and where it should hover at normal temperature for the transmission. I've searched the web and read many opinions which vary from 160 to 180 degrees for normal temperature, but that 180 seems too high to me. My 2005 3500HD Duramax's transmission temperature always seems to be around 140 degrees.
I just don't know what it should be. Can somebody please let me know?
Thank you,
Bruce
Thank you,
Bruce
