pcoplin
Apr 14, 2015Explorer II
North Shore bike rack
I bought a 2-bike North Shore rack from my buddy. He's upgrading to the 4-bike rack. Problem was, the bottom tube was to small to work with the camper.
So I used 2x2x0.25 (receiver tubing) to make a longer one. Used a 42inches of tubing, and the rest was drilling holes, and inserting their nutsert for the hitch locking pin. Took about an hour. I welded spliced two pieces of tube together, but if you buy a piece of tube from a steel yard at the proper length, you only have to transfer drill the holes you need. I used 1/2 inch bit for the rack side, and a 5/8 bit for the hitch pin.
Rack folds up nice.
THere's 3 adjustments by a hitch pin, but none of them allow me to open the camper door with the bikes on.
There's another hitch pin you pull to allow the rack to tilt back. If your truck is low the rear tire will rest on the ground, or in my case the hinge bottoms out and holds off the ground.
In reality this was all for my 3 y/o daughter. I've been carrying her bike on the dinette seat. :)
Rack folds up nice.
