Fishhunter's avatar
Fishhunter
Northern Lite
I'm looking to buy a 2008 Northern Lite 9.6 classic se, and wondering if there is anything in particular I should look at. I haven't seen it yet as its a number of miles from me. I would like to get as much info before traveling to look at it.
Thanks
  • One more thing...Don't forget to leave you're tailgate at home when you go to pick it up.
    Happy camping, Dave.
  • This is a list I found before we purchase our NL. Happy camping, Dave.
    PDI CHECKLIST
    1. STARTING POINT - A flashlight with a strong beam is a very useful tool to have. A screwdriver with a straight, Philips and square bits will come in handy as well. You should also have available the delivery invoice for the RV. It will show all the standard equipment and ordered options and should be compared to what you thought you ordered and should be referred to during your inspection. Pictures from the glossy brochure will also help in your inspection.
    Make a list of anything you find wrong, needing adjustment or unacceptable. This will serve an important role when you go to discuss the next step with the dealer's salesperson.
    You will need the understanding & cooperation of your dealer for this process, as it probably involves far more depth & detail than they normally anticipate and schedule for. Make sure they know about it in advance & try to schedule your visit to allow enough time to perform your inspection & actually get some things fixed (if necessary). You may get a better prepared rig if the dealer understands your intentions. At the very least, tell the person doing the “owner inspection” or “walk through” what you intend to do, give him or her a copy of this checklist and work with them to plan the time accordingly. A sense of humor will also come in handy!
    Finally, my assumption for this PDI is that both (if fitted) propane tanks are full, shore power is available, city water and a hose are located close by and sewer connections, a drain or a dump station is available. A fully charged battery must be connected as well.
    OUTSIDE WALK AROUND - The outside walk around should take around one hour. At this point, you're generally searching for anything that does not look right
    2. Roof Sealing & Fixtures - You will need to get up on the roof here, so round up a ladder or carefully inspect the one on the back of the unit if you are going to use it. Check that all the mounting points are solidly attached to the body and the rungs are firmly fixed to the frame. Climb on the roof and inspect all seams, gaskets and any other place that the roof material has been cut or holes drilled. Check that all shrouds & covers are intact, unbroken and properly seated on the roof. Proper polyurethane caulking should have been used to seal all places where the roof has been penetrated. Check closely around air conditioners, vents, antennas, sewer vents, and side seams. Look for any signs of bubbles (large and small), delamination, foreign objects or protruding screw or nail heads under the membrane (if a rubber roof).
    3. Windows - Check closely around each window to make sure it has been properly aligned and sealed. A gap between the trim ring & the window frame is acceptable, but it should be nearly even all the way around the window.
    4. Entry Doors - Check the gasket used on all doors for proper adhesive and coverage. Look closely at the door from the inside and confirm that it sits flush against the inside of the doorjamb. Confirm that each key works in the appropriate lock. The main door should open & close smoothly and lock with out undue effort. Check that the screen door opens smoothly alone and locks to the main door without any extra effort.
    5. Baggage Compartments - Open and close each door checking for alignment & gasketing. Confirm that each key works in the appropriate lock. All hinges should be tight and secure and the latches should hold the door tightly closed and still be easy to open. Feel the floor or carpeting and look for any signs of moisture that might indicate rain leakage. Verify that compartment lighting (if fitted) works properly. Any gas cylinders used for keeping the door open should be properly installed so as not to interfere with items stored in the compartment. If clamp type door hold-opens are used, make sure they are present and hold the door correctly.
    6. Sewer & Fresh Water Connections - Inspect this area on the trailer to make sure that nothing is broken or deformed. If appropriate at this time, make certain you understand how each valve or fitting works. Understand the proper function of the black and gray water valves. If tank flushing is installed, understand how it operates. Understand where the low point drains are for the fresh water system.
    7. Telephone & Cable TV Connections - Find and understand the telephone and cable connections. Make sure a weather cap is present for each connector and that connectors are properly identified & mounting plates are properly sealed.
    8. Propane - If the tank(s) are contained in a compartment, there should be no possible way for propane to enter into the RV or any other compartment. Understand how the regulator works and how it switches between cylinders. Confirm that a leak test has been performed on both pigtails between the tanks and regulator and the rest of the system. Locate and understand the operation of the main shut off valve (if any).
    9. Battery - Check the battery box to verify that it is ventilated and that any compartment slide mechanisms work properly. Verify that no battery cables are rubbing on any part of the frame because that will eventually end up with a short circuit and possible fire. Understand the battery type provided and how to maintain them.
    10. Paint & Siding - Carefully check the paint finish on the RV. Any problems can be verified and corrected at this point with a lot less hassle. Site down the side of the unit to check for bumps or depressions in the siding. Divide each side of the unit into 2, 3 or 4 sections and inspect for siding issues: color variations, dents or irregularities. Do the same for the ends of the unit look at places where vinyl film is used for graphics to make sure it is free of any air bubbles? Check ends of any decals for uniformity or “mistakes” that may have gouged the siding. Look closely where masking tape was used for paint graphics to make sure there is no over spray. Carefully check for surface smoothness and any place when paint coverage is marginal or where there are bubbles.
    13. Awnings - Extend and retract each awning paying particular attention to how the awning is locked in the retracted position. Make sure all springs, locks and supports work well and are properly aligned. Wiggle the mounting points for the support arms to get a feeling for how solidly they are mounted to the body.
    INSIDE FIT AND FINISH - Now its time to go inside. In general you are looking for things that are not finished correctly since it is really too late to inspect the design of anything.
    16. Cabinets - Inspect & open all of the cabinets to insure that all the hinges and latches work well. Pull each drawer out to its stop, return it closed and then try to open it like road vibration might do. Makes sure that there have been no water leaks and that all the wiring and pipes are well fastened. Inspect the linings (if any), to insure they are fastened securely. Run your hand along all edges, front & back to check for and delamination or loose edges on molding or vinyl wraps (you may want to wear gloves for this part)
    17. Molding & trim - Go over all the trim on walls, doors & furniture. Make sure that everything is fastened on well and not loose or ready to come off. Check that no nail heads or staples are protruding.
    18. Lighting - Operate every light switch and observe its function. Use the monitor panel to check battery levels. Understand and verify any battery disconnect switches. (At this point, only 12V lighting can be tested, as the unit is NOT connected to shore power yet)
    19. Closets - Open and close all closet doors checking for free operation and proper alignment. Hanger rods should be properly fastened and secure. Check out any lighting that is provided and any switches that are used.
    20. Furniture - Examine every piece of furniture to check for construction, upholstery, pattern and cloth matching. Check out the dinette by making it a bed with the appropriate cushions. Do the same with the couch or sofa.
    21. Blinds - Operate each blind and check for alignment. Look at all valances and trim to be sure they are secured.
    22. Counter Tops - Inspect all counter tops for alignment and fastening. Make sure that any trim pieces that should be there are in fact tight. Check for caulking quality everywhere there may be water, especially edges near a sink. Check the installation of sinks and faucets.
    23. Windows - Open and close every window and operate the latches. Pay particular attention to the two safety egress windows or emergency windows and make sure they operate smoothly & easily.
    24. Floor Coverings - Inspect carpet and other floor coverings in all corners to insure that they have been properly fastened down. Check areas that slide outs may roll over for pulled threads, cuts or other problems. Check closely for gouges or cuts in linoleum tile.
    25. Wall Coverings - Check to make sure that all the wall coverings actually cover and join properly. Look for any discoloration or patch jobs that may cover hidden problems. Try to find any places where there are problems, as now is the time to get it fixed while matching patterns are in stock. (Some folks suggest ordering extra fabric, carpet, and wallpaper now so that matching material is available to make small modifications or repairs at a later date.)
    OPERATION TEST OF ALL HOUSE SYSTEMS - You should be about two hours into to the PDI by now and you are ready to test all of the house type systems.
    26. Shore Power System - Now is the time to connect up to shore power. Pull out all of the AC cord, confirm the length and inspect the plug for proper attachment. Inside the unit, check any 110V lighting and switches. (If you have a 110V receptacle tester, check all outlets for proper wiring/polarity.) Find the GFI protected outlet and test using the push button. Understand which receptacles “down stream” from the GFI are protected. Any electrical problems here should be corrected immediately.
    26a. If there is a generator, start it and check the correct operation. Check that the changeover from 12 to 110 and back is done correctly. Check the voltage to charge the house batteries (to be sure the thing does not 'cook' them).
    27. Converter - Confirm the operation of the converter/charger that is installed. Turn on several interior lights to create a load for the converter and confirm no excessive converter noise or vibration. Have the PDI person explain the operation of the converter, the AC circuit breakers and the DC fuses. Make sure that there is a written list of the loads connected to each fuse or breaker.
    28. Water Pump - Your PDI person should have filled the fresh water tank, so now you can test the function of the water pump. After turning it on, you should hear it pump for several seconds, even up to a minute to create enough pressure in the system. If the pump does not shut off, there is a problem. Run water in the kitchen and bathroom sink and notice that the pump will come back on until proper water pressure is restored. Now is the time to fix a noisy pump if it is vibrating or making any irritating sounds.
    29. City Water System - Turn off the pump, connect up to city water (use a regulator if overly high pressure is suspected) and confirm that the connection works correctly. Look for leaks under sinks and confirm the operation of all fixtures again while on city water.
    30. Holding Tanks - Re-fill the fresh water tank if necessary and run water into the gray tank to verify the gauge reading and that there are no leaks. Filling the gray tank until water comes up in the shower will make it easier to find leaks inside & out. Do the same thing to the black water tank, including filling so that water comes up inside the toilet. Check for leaks (if the toilet is installed correctly, there will be no leaks!) You can fill the black water tank by using the tank flushing system (if fitted), by using a garden hose adapter for the sewer connection (through a backflow preventer) or by bringing the water hose inside and filling the tank through the toilet. This last method can be a little cumbersome, and I don't recommend unless you've done it before. Check the gauges for accuracy while you are filling. Now is the time you want to find leaks if there are any! Drain the gray and black water tanks using the sewer hose or the garden hose adapter.
    31. Water Heater - Try the water heater on propane first. A few seconds after you turn it on, you should hear the click of the igniter and the small pop when the burner lights. The red light should stay on until that process happens. If it does not ignite, then there is a problem. Turn on the AC element in the water heater (if connected) and confirm operation. Make sure you know the location of the electrical switch at the water heater and the correct operation of the interior switch. If your unit is so equipped, understand the operation of the bypass valves for winterizing. Confirm that hot (or warm water depending on how long the water heater has been on) comes out of the hot tap at the various sinks.
    32. Furnace - Now its time to understand the operation of the thermostat that controls heating and sometimes the air conditioning. Turn the furnace on and set a temperature that is at least 10 degrees hotter than the ambient temperature. In about 30 seconds, you should hear the furnace fans come on. Shortly thereafter you should hear the click of the igniter and the sound of the burner. If not then there is a problem. It could also be taking a while for propane to get to the heater, so don't worry yet! Let the furnace blow and you should get hot air at about 110 degrees coming out of all vents. Check each one. Now turn the furnace down and the hot air will gradually turn cooler and the fans will eventually stop after the furnace has cooled sufficiently. During this process have someone with a good nose checking for any smell of material getting too hot, or heater exhaust coming out. On a very new heater, there may be the smell of oil burning off internal metal surfaces. This should only last a short time. Have the windows & doors open.
    33. Air Conditioners - Some air conditioners also have a heat strip or heat pump feature so now is the time to verify these functions. Turn on the air conditioner. After a couple of minutes, cool air, 20 degrees cooler than ambient, should be coming out of the registers. If you unit has ducting in the ceiling, make sure a good airflow comes out of each register. Learn how to clean the filters at this time.
    34. Propane and Carbon Monoxide Alarms & Smoke Detector - Now is a good time to check the function of these alarms. The PDI person should have a small canister of gas that can be sprayed at the alarm to test its operation. Have them perform this test while you watch and learn how the alarms work. Confirm that there is a new battery in the Smoke Detector. (Write the date on it for reference) Activate the test button to check operation of the smoke detector. Understand how to turn it off.
    35. Refrigerator - Most modern refrigerators work on propane or AC and have an automatic mode that gives preference to AC and then will switch to propane if AC power is not available. Understand the controls and the status lights and set the unit on propane. The RV may need to be unplugged for this to happen. Go outside to the refrigerator vent grill and make sure that the propane heating column is lit and heating. While the refrigerator grill is open, check to make sure the drain line is positioned for proper drainage. Set the temperature at the highest cooling setting, because setting it to lowest will typically cause the coils to collect moisture and ice up. Come back in about 10 minutes to feel that the coil/fins are actually starting to cool.
    36. TV VCR Antenna and Switching - For the most through test, bring a small AC/DC TV with you for the initial test. Review and understand the switching system that allows the selection of viewing channel on the front and rear TV. Raise the TV UHF/VHF antenna and learn how to turn on the amplifier and the DC outlet. Find out the power rating of the DC outlet and compare it to the load of the equipment you will connect to it. Activate the control on the front TV that scans for local stations. Learn how to rotate the antenna to maximize the quality of the picture.
    37. Air Vents - Test the operation of kitchen and bathroom air vents making sure they open and turn on properly (if powered). Verify that they retract and close tightly. Check any other vents for proper operation.
    39. Propane Stove - Turn on one burner of the stovetop while the air conditioners and Microwave are running and the automatic igniters should cause a strong spark to light the burner. Turn on the other burners to verify that there is enough propane flow to operate the refrigerator, water heater and all the burners. If everything is OK, turn off the burners on the stove. If your unit has an oven, then understand how the pilot is lit and verify its operation now. Note: Sometimes the burner igniters interfere with the operation of the thermostats for the roof AC.?? This is the time to find this problem.
    40. Summary - You have now done a simple test of the major house systems and can shut everything off. By now, you will probably have a list of things that you feel need correcting, but it may also be near the end of the day. Decide if you are going to accept the trailer as is or if it needs to stay with the dealer. If you accept the unit and it is appropriate, plan on camping near the dealer for the night. This will give you a chance to further test the various functions. Prepare yourself for waiting until these things are corrected and don't be tempted by the PDI person to sign the acceptance paperwork just yet. For a really serious checkout of your new trailer, you should "dry camp" the first night and not be tempted to hook up to shore utilities just yet. Bring enough kitchen equipment and food so that you can prepare an evening meal. There is no better way to test the living facilities than to actually use them. Don't be tempted, since you've had a tough day, to go out to eat.
    41. ACCEPTANCE - When you are satisfied that all systems are "go" then sign the acceptance papers that the PDI person will anxiously provide for you. Schedule your first return trip to the dealer for about a week to a month from now. You are now ready to take your "shake down" cruise.
    42. SHAKE DOWN CRUISE - Select an interesting destination about 100 miles away for your maiden voyage. Actually use all the systems multiple times to try to detect any infant failures (electronic equipment fails at greater rates at the beginning of its life). Carefully note any problems or discrepancies in a list and make a copy for the dealer when you take the RV in again
  • We bought a NL 2008 10.2RR model last fall and love it. You will need a 2" spacer on ford trucks 2011 or newer as we originally had it on a 1990 but with our 2015 ford we had to go 2 1/2" because of the dually lights. Check for leaks and any delaminations. Keith at NL is really good if you have questions about anything.
  • You might want to make a list of all the features you want (and even everything you want to examine) and check them off as you look at the camper. This will also get you to focus your attention on many different areas.
    Before we bought our Northern Lite, we rented a NL Sportsman (on a new Ford) from CanaDream. Noticing what we liked and what we didn't, we decided that we wanted a NL 10-2 CD (which was not what we previously thought we wanted). Moreover, we discovered that some of the used NLs had more of what we wanted than did the new ones.
    The 10-2 CD has enough headroom for us to sit up in bed and more headroom over the sink. Plus, it has cabinets over the dinette. The Sportsman did not have these advantages.
    Plus, turn everything on (not at the same time) to see if it works. For example, one of our Happijac motors did not work the first time we unloaded the camper. The seller subtracted the cost of replacing a burned-out Fantastic Fan motor (which he brought to our attention).
    And ask the seller to explain how to operate everything, especially things you're a bit fuzzy about.
    We love our Northern Lite. Good luck with your looking.
  • Northern Lite is a very good choice. Other than the obvious structural damage, water damage is the only thing that I can think of to look for; move the mattress and check under and around it for mold; check inside all the closets and cupboards; check the roof for damage or holes etc.
    Nothing should ever be bolted or screwed to the roof other than the ceiling and fridge vents, the factory installed TV antenna, or air conditioner. If it has an aftermarket air conditioner, be sure that the installer used the N-L spacer between the A/C unit and the roof. That spacer is needed to properly support the A/C unit. If it has solar panels or any other items on the roof, they should have their mounting brackets glued/taped (3M VHB tape) to the roof. The roof is strong enough to walk on but not thick enough for bolts/screws.
    Take a look at the N-L Owners forum Click Me. Join our group and ask questions. The forum members will assist you.
    LeRoy
    EDIT:
    I forgot one thing. If your truck is a 2011 or newer model, you will probably have to put a 2 inch spacer under the camper so that you have clearance over the cab. This will probably be true for most older campers.
  • We have a 13' 10-2 cdse. We liked the curved dinette better in the 9-6,but my knee issues forced us to get the larger bath in the 10-2. We've owned six RV's, and hands down our N.L. is the best RV we've owned. So much better built and easier to maintain. Probably 75% less caulk to look after than our others. Their pricey, but the quality is there, IMHO. Good Luck, in your search.
  • In my opinion, NL is one of the nicest best quality campers out there. If I ever sell this Lance, NL will be in my short-list for the next one.
    Just make sure it's been well taken care of, and no water damage anywhere -- anything else - like appliances - an always be repaired/replaced.
