jaycocreek wrote:
billmilner wrote:
I installed a Olympian Wave 3 heater in my NS850SC for boondocking. Question is should I expect this to heat my camper when temps outside are 30F, cause it won't. Maybe cause the canvas sides or the heater just not working? Thank you Chris
I have used the Wave heaters in Motorhomes/Fifth wheels/Travel trailers/Pickup campers and tents..They do a great job if you pick the correct size of heater..My Wave heaters in pickup campers worked really good in hunting weather..Not as well in tents..I would suspect that a Wave 6 would be a better option with canvas walls.
I used a Wave 6 in a 10X14 tent down into the teens and it kept the middle of the tent warm but the closer you got to the walls,it chilled down.When I used the Wave 8 down to 3 degrees hunting in a 30ft trailer,the Wave 8 coupled with the factory furnace kept the pipes from freezing and the front room nice and toasty.
There are alot of anti catalytic heater posters, which the majority have never owned one..I cannot give a real answer to your issue because I have never owned a pop-up but they work dandy on hard walled campers.
Thought I don't have one in my TC (have conventional forced air) you won't find me dunning a catalytic heater. I use them in my hunting blinds in the winter. Usually a Big Buddy though. Keep me from freezing my butt off.
I would not recommend one in a pop up TC (what I have as well) there is substantial heat loss through the canvas, winter package or not. Forced air works better.
