SidecarFlip
Oct 21, 2017Explorer III
joe&julie81 wrote:
I'm very close to ordering a 950sc. I just have two questions for long time NorthStar pop-up owners, as I will be ordering sight unseen. 1) does the cabover bed to ceiling space (23in) seem tight to claustrophobic or is it easy to get used to? 2) Have you ever had or know of any delamination problems with these campers?
Not owning one but owning a competitor, no soft side pop up will have as much head room as a hard sided unit and none will have an excessive amount anyway. None are 'easy to get into' unless you are extremely agile and why we have a bunk ladder....
I find a pop up's bunk to be less 'constrained' than a hard side because you can open it up and have screens all around, whereas a hard side has a window on each side.
If you suffer from claustraphobia, a truck camper of any design isn't for you. A motel is.... Truck campers are about maximizing living space in a minimal area.
Far as delamination is concerned, any Filon sided camper will delaminate if the seals aren't maintained properly and water gets under the Filon, between the it and the walls. No difference between a pop up and a hardside. You get the sames issues from the same lack of maintenance.
