deltabravo
May 23, 2014Nomad
jmtandem wrote:
Somebody forgot to take the shop vac and clean up the debris field.
Agreed.
But this is the same thing that I see on ANY RV, except a $200k + diesel pusher.
The production folks at RV factories don't spend much (if any) time cleaning out the nooks and crannies of the cabinets and appliance enclosures.
/rant off.
Back to the tie downs. A wider piece of angle aluminum would suit me more too.
THe small piece of plywood between the two metal pieces seems really cheesey. The backing plate for the tiedown bracket bolts should have been properly sized, so it butted up against that piece of angle aluminum, eliminating the need for a cheesey plywood spacer.
Send this info to the dealer so they can notify the factory. There's still room for improvement in my opinion.
I believe that Apache Camping center has pretty good pull with the factory, because I am sure they are the largest AF truck camper dealer.
