towpro
Jul 02, 2018Explorer
Frank Mehaffey wrote:
If this is one of the Sirius' add ons, for installation, I put my antenna on the front of the hood,
Frank, his problem is he has factory sirius radio, but the antenna is on the roof, and the truck camper blocks the antenna from receiving at times. What we do is put an aftermarket antenna (just like your sirius add on used uses) out on the hood, than run that new antenna cable into where you can plug it into factory radio harness. On Ram I have found its easy to do this by removing the A piller trim as connector is right above dash under this trim.
