bryanc's avatar
bryanc
Not getting propane in RV -- bad regulator?
So I have a 22 foot KZ MXT22 Toy hauler. Pretty standard type of travel trailer, and it has 2 20# propane tanks on the front. again, fairly standard setup, the tanks both have pigtails that go into a single 2-stage regulator. I've only had the RV for a couple of months, so I am still getting used to where everything is.
Took it tailgating at PSU this weekend and we didn't have any propane at all in the trailer. None for the fridge pilot, none coming out of the cook top, and nothing coming out of the quick disconnect that is on the back side of the trailer, where you can hook up a grill.
I searched the entire line, no leaks, didn't smell anything at all while I was looking around. No kinks in the line either.
I'm thinking -- can it be the regulator? Do these go bad and, if they do, is it common that they will just not allow any propane at all?
I've already ordered a new one - $30 Camco job from Amazon with the lever so you can switch the tank. But I am curious if anyone has had this happen.
Bryan
Replies have been turned off for this discussion
