2012Coleman
Feb 09, 2015Explorer II
OP wrote:This statement is a little in the weeds as you most certainly have more weight being subtracted from payload then your yourself, a purse and a water bottle - its called tongue weight, and at 6500 lbs dry, that's around 850 lbs depending on what percentage you calculated it. This number goes up when you load the TT with gear so the rule of thumb is to go with the gross weight of this trailer which I see is 8500. At 13%, your tongue weight is 1105 lbs. Now add on the weight of the weight distributing hitch, propane and battery, and payload is non-existent/exceeded just by hooking up.
I can only answer a couple of those questions. First, the payload is 1500 lbs., but there was nothing in the car but me and a few random hair brushes, reusable shopping bags, my purse, and a water bottle so I should not have had a payload issue
Hopefully you now understand why tow capacity is a number that will never be reached as you typically run out of payload capacity before reaching tow capacity.
Keep this in mind when shopping for the new TV. Don't get enamored with tow capacity - it's a fantasy.
