Peg_Leg
Oct 26, 2017Explorer
I've replaced a faucet because the line from the valve to the center had burst. I've had the plastic strainer bowl on the water pump crack along the threads. That one had me replacing the laminate flooring and some other repairs. All this because I would be using it again and I tried just letting the water drain with the faucets open and the low water drains open.
I have never had trouble when I use the pink stuff. Now I'll be hitting the road in about 3 wks so I have tried blowing the lines out with the air compressor. Never done it this way before and I hope it doesn't bite me down the road. I took the strainer off and cleaned the screen and made sure there was no water.
